Jake S.
clueless...
My three stickers look just like Mel's do, but say 175hp
whats the reason for pullers running such high timing, in diesel power mag, there was something on a cummins and the was talking about running 50 degrees timing on a 1200+ puller
The reason a direct injected motor will start with lower compression is cuz they spray the fuel DIRECTLY at the piston where temps are highest rather then being sprayed into a pre-chamber where its cooler.
I think the higher injection pressures have more to do with over coming higher cylinder pressures from higher boost amounts then with starting, and to make sure the fuel is atomized rather than puddling on the piston top. Atomization has more to do with the injector than it does the pressure.And they have higher injection pressures for better fuel atomization. Broken record anyone?
jhnlennon said:Atomization has more to do with the injector than it does the pressure.
How much does atomization affect an IDI considering that the fuel gets sprayed into a pre chamber anyway??? Wouldnt that negate the affect of atomization once it hits the prechamber walls and the fuel molecules re-combine?
