frankenwrench
overkill is under rated!
Just ran across a sweet deal on a solid front axle. Everything I need is there to swap over to my 91 f250 7.3 IDI 2wd from a 1990 f350 cc dually 7.3 idi. Here's the deal, I have swapped the 10.25 my truck came stock with for a 2001 srw with the 3.73s. the front end I will be getting has 4.10s in it and I want them to match and have found nothing for it that will fit the application. I assume since the doner is a cc dually that it is cab and chassis and I will have to move the spring perches on the front axle housing. But still want front and rear ratios to match. Any suggestions are welcome and any pointers as well, except putting 4.10 back in the rear. Unacceptable...... Love my 3.73s too much now.
