funnyman06
well the rear axle might not change HP numbers, but it is a torque multiplier. So even if the HP numbers are the same the tq numbers should be higher with 4.10 compared to 3.54.
Oh yeah,
Hey Darrin..... Dennis was bummed he didn't get a chance to see your truck. He is repowering a superduty with a Scheid Diesel built Cummins (See Aric's photos)...... and he wanted to see your conversion. Speaking of that truck, it has the low pressure mounted under the cab and wanted to talk to Barney about keeping it oiled.
Heath
Interesting stuff. Wish I could have come to the Rally. I don't see many IDIs on the dyno... at least not since the '80s and early '90s. My '86 has a large number of dyno miles over the years. Usually runs in the high 180s. A couple of years ago, it made 192 hp on a Superflow at a local tech college. A year later, it only made 178 on a Mustang at Ashtabula. Go figure. As was stated earlier, Superflow seems to give the most accurate numbers overall. Dynojet seems to be the most optimistic (we call them a "magazine" dyno). Mustang is somewhere inbetween, but calibration and operator competence has a lot to do with it. Older trucks are easier overall because you can hold them into a gear. The electronic trucks, especially the Allison D-Maxes, always shift at the wrong time.
Im not trying to argue, just understand. Gearing might not change engine output but why does it not change power at the wheels? Do they compensate for it somehow?
AAAAAAAAAAAHhhhhhhhhhhhhhhhh not even one HP difference I'm smelling a rematch Gary
wow your truck makes more power than anyone who dynoed and you have a first generation banks non gated turbo, how much boost do you see? and what is done to your ip? and you have a c-6 trans
Turbo results
15 Chris Barber 148.7
on a good note, i think my some of my rings seated on the trip home
