2004 explorer fuel filter???
94f450sd
somewhere,ma
where is it?i havent touched one of these trucks yet so i have no idea where the filter is.my sister in law in florida needs to change it but the dealer and shops want 200.00 to do it :eek: :eek: sounds a little out rageous to me.so she asked if i knew where it was so she could do it herself.sooooo where is it?
tonkadoctor
none ya bidnes
I beleive it's on the right side under a cover behind the exhaust. It's on the chassis down there somewhere, a real PITA.
You will need to disable the electric pump and bleed the pressure first. You will also need a special tool for the quick connect fuel fittings available at most auto parts stores.
Good Luck
m2rtin
