2003 7.3 power stroke shuts off after 15 minutes
InnovativeAV
Erie/ PA
SOLVED. Thanks to greenskeeper. Glad that I didn’t dump a ton of money at it but before we did the H pop we replaced the IPR and that’s what it was
InnovativeAV
Erie/ PA
Ran good for a week and now it is back to doing the same exact thing
Diesel D
Kaukauna WI
Try checking the ICP sensor.....should have about 5vdc.....if there's any oil around the pigtail plug, that's a sure indication of failure....
blvvick
Mott, North Dakota
Drop the tank and check the socks. You might need to pick out the chunks.. it’s super cheep to check and that was what happened to me
blvvick
Mott, North Dakota
The plastics break up and float around so when you fill up and drive they move around in the bottom of the tank. The suction pulls them into the fuel pickup and when the fuel pump stops sucking they are released (if your lucky) and float around until they get picked up again- eventually one will clog the line completely and then your in big trouble
Nanohawk
