1999 F350 7.3 power stroke wont run?
Status
Not open for further replies.
h2odrx
Anti-O
Coastal Neckville, NC
I have swapped out all the relays with another truck of the same that my father has, and they all work. i did however, even though it was very risky used ether in it to see if it would run. It did want to run, but did not have the fuel to support it. Everything from the fuel tank to the fuel filter is working. I have come to think that it is either the HPOP or the injectors them selfes. my question is, which one of these would be the first to typically let go? If i am not right about this, what else could it be?-cuss
So did you buzz test the injectors? We had a church shuttle that did this same thing we chased it for ever it ended up being the IDM was bad.
Ladman
Ladman
plainfield, CT
Im not sure what you mean by buzz test? all i know is that i sparyed the air intake with the eathier and the engine wanted to run. If you could explain the buzz test to me, i will give it a try
Status
placidoert
