This build is my dads. He started with a 1991 7.3L IDI 4x4 diesel. It had about 550,000 miles on it when we got it. Not long after that he decided to switch it to a 5 speed manual trans, and then from there I installed a 1994 factory turbo ATS kit for him and adjusted his fuel pressure and turned the boost up to 12 psi bringing power from 155hp to more like 230hp.
The truck pulled well but it was old and tired. After a valve train noise started in after an 1100 degree egt hill pull he decided to rebuild the truck. The original plan was to rebuild the stock IDI but after finding a whole running power stroke truck he just decided to swap to a powerstroke and rebuild it in the process. First plans were a 4X4 and manual trans swap on the powerstroke truck but it has snow balled into plans for 400+hp. Here are the trucks.
1991 F350 4x4 high boy 5 speed zf 7.3L IDI
1996 F350 2wd auto Power Stroke 7.3L DI
