1994 F250 Transfer Case Control Lever
Twostacks
howell, NJ
Does anyone know if the transfer case control lever/unit uses same part for a manual or an automatic transmission??
Thanks
6 Nebraska IDIs
Broke two of those POS shifters in 4 hours the other day.
Dumbest design ever. Why change something that worked so well, ie the 87-90 style TC shifter design. Its impossible to break one of those.
Diesel_brad
Dunce
gilbert pa
Yes, it ceased up so I used a BFH on it and cracked the housing:eek:
I'll need to get me another no fixing the one I cracked
Thanks
Vince
O on the contrair. I broke mine and had it tig welded. Then i cleaned her up and added 2 grease fittings. mine will never seize again:D
Optikalillushun
Coal Region, Pa
95% of the ones @ the junkyard here are broken. all crack in the same spot. i have a shifter set up from a 89 F-250 im gunna try and see if it works in my buddies 95 F-250.
