1993 front doors....will they fit 1980-1997?
nicknd
U.P. of MI
Will 1993 model year doors fit any f-series truck from 1980-1997? The curve of the front of the doors looks to be the same on all these years....
snicklas
6.0 and Loving It!!
Staff member
Greenfield, Indiana
Yes the doors are the same from 80-97,
however,
The vent wings changed in 87 I believe with the new dash. The older ones will not open all the way with the door closed, the Vent is smaller in the 87-97 I believe. Also, on the CC doors, the 80-86 have the Small window in the front of the rear doors, and a 3/4 size moveable window. In the 87 on it is a full sized window that rolls up and down and no small stationary window. You can on either, change out the vent assembly, or the station assembly and window and it will be the "correct" setup.
rjjp
Needs to go test
Clare, Mi
The vent change was for 92 and later, they made the front flat instead of a curve.
Alleycat
