Ferd_Diesel
I am trying to fix my cruise control on 93 7.3 with e4od. I'm getting no power to servo. I get to this part of the test.
No Power to Servo
B1 – Check ignition circuit
- Make sure step A1 has been done.
- With ignition in the Off position, measure the resistance between pin 10 and a ground on the chassis.
- Is resistance less than 1 ohm?
If so, module power is okay, recheck A1; If not, there is a ground circuit open. service as required
Power is okay but ground circuit open?
Does that mean a bad ground? Horn works and fuses good. If it's the steering wheel ground how hard is it to replace?
Sent from my SCH-I605 using Tapatalk
No Power to Servo
