1990 E350 Club Wagon....
I have a "mysterious" fuel leak. I haven't pulled the dog house yet, but the leak seems to be coming down the right front area of the engine (near fuel pump). Peaking through the hood, I can see traces of 'wet', but can't tell where the source is. At idle, I don't see anything dripping....
The leak is MUCH worse at high speed vs idling around. I drove it around in the field for a few days and nothing. Drove it once on the road and dang.....
Some of the return lines I can see don't look wet. But you can't see much from the hood. At idle in gear, I kind of think it's not running "right".... like a miss, lacking any better description. With it sitting for a few days, starting is not an issue.
I'm thinking it has something to do w/ a return line (maybe) or worse yet, a high pressure line. At idle, it's fine, but crank it up...... Or maybe something got loose???? Is there anywhere on the IP that would leak that much at higher speeds???
Ideas?
(I was going to drive my IDI for a few days since the 99 PS van has a CPS issue..... need to schedule the dealer look see.... recall. Didn't want to risk driving the PS and having it stall on me at 50MPH..... looks like I'm stuck driving the GAS car..... ) And both vans are FULL of diesel too
Ideas?
