furfishgame
First off i very much appreciate the help all!
When the event happened it lost all engine power, like the throttle cable broke (i know that because it happened last week) as soon as that happened i shoved the clutch in and looked down and i had 0 oil pressure. And the engine kinda tumbled to a halt similar to if i just shut off the ignition All this with in a few seconds. I didnt hear any rough noises and the engine turns over normally
I smell no diesel in the oil and im not sure if its higher than it should be as it leaks around a quart every 2 weeks but ive been driving work trucks home more than normal lately.
I put a new lift pump on and it seems to get good pressure past the filter, how ever i took an injector line off after trying to bleed the air and the fuel sputters out of the line, kindof in sync with the lift pump stroke. It doesnt seem to really be spraying air, just throwing a shot of fuel, then stopping
