1989 Ford Tachometer
aofarrell2
Turbo Desirous
IA
Okay, so I've got a 1989 Ford F350, got a cluster out of a 1988 V8 gasoline. There are 4 wires going to the tach, on the clusters gray connector, these are the numbers:
Pin 4 - Ground (BLACK)
Pin 6 - Tach signal from coil (DARK GREEN/YELLOW?
Pin 7 - Unknown function (BLACK/YELLOW)
Pin 13 - Unknown function (RED/YELLOW)
So my question is, did I get the first two right, and what are the second two for?
Thanks!
--beginningjockey
Hit Man X
Huffin Diesel Smoke
Texas
I have a factory Ford ETM for '88 MY, maybe it will help?
Pin 6 - Dark Green/Yellow
Pin 7 - Black/Yellow
6 runs into a 1.8 k ohm resistor back to the positive side of the coil
7 ends up just being a ground after various stops along the way
13 appears to be simply a switched 12V to put power to the cluster
I am not an EE and reading these diagrams are not my forte. But it seems simple enough. Haynes also has a decent power flow diagram too.
opusd2
BFE, WI
Ya know, this would be great to explain clearly and make a sticky.
Probably because right now I am so damn tired I wouldn't understand if shown with a ladder diagram
