Flagship
Before I moved, a little over 4 years ago, I had the Ford dealership do the following:
2 new batteries
new battery cables
new alternator, wiring harness, regulator
all new belts
new radiator hoses
new heater hoses
new heater core
new tharmostat
flush and replace coolant
two new horns
new tach sender
new wiper motor and both wiper transmissions and blades
new upper and lower ball joints
new tie rod ends
new front shocks
new power steering pump
new rear spring hangers
new rear springs
new rear shocks
new rear wheel bearings and seals
drain and flush differential (had water in it)
new wheel cylinders
new steel hoses up to master cylinder
new brake shoes and spring kits
new drums
new parking brake cables
new tires Toyo open country
replace and paint one wheel
complete exhaust system
repair wiring where dome light would not come on when drivers door was open
Like I said, a practically new truck for a small used truck price.
With a one year Ford warranty.
About two years ago, I replaced the vacuum pump.
About three months ago, I had to fix a flat tire.
About two months ago, I replaced all the glow plugs.
Other than that, Oil / filter changes, grease and diesel fuel.
Oh! And windshield washer fluid.
2 new batteries
new battery cables
all new belts
new radiator hoses
new heater hoses
new heater core
new tharmostat
two new horns
new tach sender
new tie rod ends
new front shocks
new rear springs
new rear shocks
new wheel cylinders
new drums
