1987 hvac
5 oclock
Oregon
Ok so upon discovery of the mice (and crap,*****,nuts, etc) problem. I pulled the hvac apart. Is it supposed to come apartm Doubtful.. definitely not ideal. However it does have locking tab areas along with a bonded plastic track that aligns the pieces. It's apart as shown. My ideas is to sand the mating surfaces to bind adhesion and then use rtv to reseal.
The rtv will have to play two roles. 1.make it air tight. 2. Bind the two surfaces. As many know the factory units are suprisingly pretty rigid upon removal. I want to retain that same construction. Before I took the plunge figured I would see if anyone else have been here and done it?
My concern is achieving a very non existent voc once cured.
Sent from my SM-N975U using Tapatalk
chillman88
Central NY
RTV might work, personally I'd try something stronger like windshield urethane. Once fully cured it shouldn't emit odors. It'll stink pretty good until then though! I'm just thinking of that because it should stick better than the RTV although the RTV might work just fine.
I'm certainly paying attention to this. I'll be doing this to my 1987 here shortly and have no experience with the Brick Nose HVAC system. Just be aware that windshield is very thick and difficult to squeeze out to apply when it's cold/cool. Not to mention that it's about as bad as antiseize when you accidentally touch it.
gnathv
Athens, Al
I know this sounds crazy but the best adhesive I’ve found is Shoe Goo. Easy to work with and when it cures it’s going to stay together.
5 oclock
Oregon
Not crazy at all! That's what I am thinking...as always..there has got to be a better way. I have thought about attempting to reweld the plastic. There are actually parts that have stapled locking the rim together. In general though my experience is that plastic and fasteners aren't a good recipe especially when you add heat and time.
catbird7
PA
You did exactly what needs to be done! That's the only way to get rid of that stinky mouse **** odor. Scrub everything with Clorox several times. Reassemble with your favorite adhesive and maybe consider a combination like epoxy (JBWeld or two minute epoxy) at strategic locations and rtv at others. It's work worth doing "one time correctly" vs a three time learning experience.
