1986 Crew Cab Dually Conversion 6.9 Maryland $4,250.00
Tim4
Md
1986 Ford Diesel Dually four door conversion truck by Kodiak. 6.9 diesel with 4 speed transmission. Rear wheel drive. Shows 64,*** miles on odometer. Mechanical speedometer starts over after 99,000 but it doesn't look like this truck has turned over more than once.
Cloth interior, fiberglass rear fenders, grille guard, rear window screen, air dam on roof. Paint is thin but appears to be original on most of the truck. The underside is mostly free of rust.
The tires have tread but are old and not to be trusted for long. The truck starts with some aid, runs and drives well. There is a new starter installed but all systems will need to be gone though prior to putting the truck on the road. Systems likely needing work include; glow plugs and return lines. The truck comes with door and ignition keys but the ignition switch needs updated.
This is not a daily driver yet but will make someone an incredible tow rig and family travel wagon. Sold as-is where is. Clean title. $4,250.00
