TBigLug
I Miss U Baby Girl
Well, it's getting warmer so my project bug is getting the better of me. I'm thinking of taking the 6.9 and C6 out of my '86 and putting it in a 70's extended cab F-250 or F-350 then putting the gasser in my '86 and selling it. Couple of questions to those who have done it.
What is the frame width difference between the 70's and 80's trucks?
Which motor mounts can I use?
What's the difference between the C6's used in a divorced t-case application and the 2WD?
Which years had the divorced cases and which had the married cases?
Did the 70's trucks use galvanized fuel tanks (aka bad for diesel fuel)?
Will a 460 radiator be big enough for the 6.9?
Here's my thoughts...
It should be fairly straight forward. Pull the motors out of both trucks. Drop the 6.9 into teh 70's truck. Build some kind of stub shaft to go from the back of my C6 to the divorced case. Shifter linkage and accelerator linkage would probably have to be modified to work on the 6.9. Replace the original tank with a plastic one. Plumb my water seperator in somewhere along the fuel line. Install an electric lift pump since the 460 would have a mechanical one on the block. Install my glow plug solenoid with a manual push button. Putting the gasser in the '86 should be even easier since I'd leave it carb'd. My main concern would be getting the diesel in the older truck. I love the 70's bodystyle and I thiknk with the 6.9 in it it would get good enough fuel mileage to still be my DD and the 4x4 and probably 4.10's would make it a great hauler. Throw some load range E 33's on it, a gooseneck ball in the bed and roll out.
Any ideas or thoughts, I'm all ears. I think there'd be more room in the engine compartment for adding a turbo later on. Regardless it'd be cool as hell.
