1980 F250 7.3 idi swap electrical question
Theaxehand
Martinsville Indiana
I dropped a 7.3 idi with factory turbo in my 1980. I know what I need to do the make the engine work, I am not sure what I need to do for the charging system. How do I adapt the newer alternator (93 engine) to the older truck? Any input is greatly appreciated! Thanks!
My guess on the alternator is that it's a 3G swap. There's been threads on doing this and some have some pretty good pictures. I do have to admit that most of us only swap the alternators while doing this. Not the entire engine. ;Poke :joker:
Theaxehand
I prefer the path of most resistance, it forces me to learn more.
hacked89
Bucks County PA
Hey youre taking it easy by merging with the 351M harness ;Poke
I can look at a diagram for the 351 80 harness late tonight or tomorrow if someone doesn’t respond by then
Austin86250
idaho
So factory turbo I’m presume the motor is serpentine meaning it’s a 3g style so 4 wires, let’s see how well I remember colors
Yellow- charge post
Green- 12v key on
White- little plug next to voltage regulator
Charge wire- battery I use 4 gauge
I used the 12v key on that supplies the 80’ voltage regulator that’s on the wheel well so you may delete on the voltage regulator and corresponding wiring
