MIDNIGHT RIDER
- Joined
- Sep 29, 2005
- Posts
- 4,639
- Reaction score
- 38
I have a 1972 F-250 4x4 Hi-Boy with a (so I was told) 390 and automatic.(all this automatic junk was later installed; it came original with a 4-speed.
This engine and transmission, although very drivable, is just so much scrap iron to me, as I have a 1st Gen. Cummins and 5-speed sitting on the pallet awaiting time for me to install it.
To start this truck, I have to dis-connect the in-line filter and pour it and the fuel-line full of gas; then, I have to dribble gas in the carburetor, over and over and over, start then die, start then die, start then die, about a hundred times until it finally decides to sit and run on it's own.
Once running, it will go all day.
If I have it running one day, I have to go through this mess all over again the next day.
YES, there is a nice brass check-valve in the line just ahead of the see-through inline filter; regardless of this check-valve (Yes it has been tested), the inline filter will be bone dry the next day; I don't know where the gas goes.
I have a low-pressure A/C-brand electric fuel-pump that I intend to install in order to fore-go all this priming non-sense.
Keep in mind that I only wish to be able to move the truck around the place for mowing the grass, and occassionally to move trailers around the place.
I am not hitting the highway for hundreds of miles.
My question is :
1. Can I simply route the fuel line through the electric-pump, leaving the mechanical-pump still operative.
2. Should I dis-connect the lines from the mechanical-pump and let the electric do it all ??
3. If I go with situation #2 above, must I also remove the old mechanical-pump and employ a block-off plate; what would be the result of just leaving it mounted ??
Thanks.
My question is :
Thanks.
