12,000 lbs of 5 th wheel trailer
Max Speed
New York
What can I say Im lucky....
SLC97SR5
UT
Not great pictures but the '94 CC F350 LB 4x4, E40D, fuel turned up 1 flat, ATS upgrade on factory Turbo, 4.10's and 265's gets the job done.
Load: 2 Toyota's, 2 Quads, 1 dirtbike, 1 FJ80 front axle, ALL our tools and spare parts
and fluids to supply 5 vehicles plus a set of tires...
GRU
fear the chicken legs
fredonia pa
holy ****!! you stole my 4runner! thats what i want to see behind mine is my 4runner and my buddy's 4runner on the same gooseneck heading out to uwharrie. i honestly thought it would be too much weight though. figured id get some hassle seeing a SRW f250 pulling an obviously overloaded weight. it sure does look good behind the truck though, how much did you gross?? that is if you weighed it.
WrickM
Richmond VA
No one mentioned Evan's Waterless coolant, so i will. I've heard a lot of guy brag about the additional cooling capacity and the 375degree boiling point will keep bad things from happening if you do get too hot. just another option.
