trugertha1
hello all. i took the plug out of my 10.25 today, and noticed that it had what smells like and looks like burnt grease, also what was on the end of the plug was very dark. my question is why does it smell and look like burnt grease haha is this just the ls crap off the clutch mixed with the fluid?
ill be changing the fluid 2morrow as the rear end is leaking so ill have it open to check it out, can i see this clutch wear? anything else i should look for while i have it open?
o also the breather tube? was capped off would this cause problems?
thanx alot.
thanx alot.
