C6 fluid change advice?
XOLATEM
Virginia... in the brambles
Have seen several now that didnt have a plug.
I knew a torque convertor rebuilder that would weld up the holes...less chance for a leak...
I still like to be able to drain 'em, though...
If they came from the factory without drain plugs...I never saw one...
if I had just bought a convertor...and it did not have a drain plug...I would call them to take it back...
Jim993
Prescott, Arizona
My '85 F250 4 x 4 C6 has 270,000 miles on it and is fine. I have used Red Line D4 full synthetic ATF since 1998 when I bought the truck at 140,000 miles. Not long after I added an external transmission fluid filter in the hot fluid line from the transmission to the radiator cooler AND a big auxiliary transmission cooler in front of the AC condenser. I change fluid and external filter at no more than 30,000 mile intervals. The external transmission filter adaptor uses a WIX 51515 XP or equivalent. I have never drained the torque converter but early on did several fluid changes at short intervals.
dieselmainiac
