those of you that have done 12v swaps to replace their idis, what kind of snags did you run in to doing so? What extra expenses came up you didn't forsee? did you use destroked.com or fordcummins.com for adaptors/parts?
I'm on the fence about doing the swap, if everything went right it would cost me about the same to put a 2nd gen cummins in my truck as it would to build the idi I want. And the cummins would have lots of room for improvement, where the idi would be at it peak (and only maybe 300hp) unless I went lowering compression and what not.
I'd really like to put a dt360 in it, but this is my dd, i can't afford the downtime or going out on a limb into new territory like that. I'll leave that up to my uncle and his 88 4x4 cc dually.
