'94IDITurbo7.3
HAMMER DOWN!
The vehicle is a 2000 dodge durango w/4.7L gas engine.
I know this is ford IDI territory but i am sure that you guys have other vehicles than ford 6.9L and 7.3L diesels. Anyways this is a generic code so even if you have a BMW it will still mean the same thing.
The other day my mom was driving her 2000 Durango w/ the 4.7L engine and all of a sudden the check engine light came on and it started to idle real rough. When she got home the exhaust reeked of raw gas. I got out my code reader and i got DTC PO201=injector circuit open cylinder #1, cylinder #1 misfire, cylinder #3 misfire, random misfire. when i start the engine i get white and blue smoke out the tailpipe. Today i was going to drive it to school to put it on a much better scanner than what i have but then i looked at my oil pressure gauge. When you start the engine the oil pressure moves right away like it should. At idle oil pressure = ~30-40psi. the weird thing though is once you give it some throttle and start moving the pressure jumps up to ~90-100 psi. then you let off the throttle and hit the brakes back to 30 psi.
If anybody could elaborate on the code i got and my oil pressure issue it would be greatly appreciated.
I did already post this in the dodge gasoline section but the activity there is almost nothing.
