seawalkersee
It needs a turbo...
Engine rebuild and in as some of you know. I have to pull the trans out to speedi sleeve the rear main. While I am under there, I find there is coolant and leaking. ARGGGGGGHHHHHHH...so I get to looking and find the block heater is leaking. Not that big of a deal since it is leaking from the outside/seal.
When I tightened it, it started to leak a bit more. So, can I take it out and reinstall it with a new o-ring or do I need to get a new one? It is not leaking from the bolt, but is it going to when I put it back in? Is there another o-ring there? Does anyone have a pic of what it looks like on the back side? Will I destroy it pulling it out?
SWS
SWS
