gatorman21218
Well I was heading home from the river when my rear antilock idiot light came on. When it did my tach and voltmeter went crazy. My FM radio also turned to static. This continued for a little while off and on then went away. About 45 minutes later it started again but this time my headlights and my dash lights all dimmed out. The engine still ran like a champ that she is. I was on the phone with Diesel JD trouble shooting and thinking if it might be low gear oil tripping that idiot light (remember that pinion seal question i had last week? I havent gotten around to it yet) Just then I heard a crackling noise and my brother who was riding shotgun mentioned that the heater core was REALLY HOT. I pulled into a gas station and popped the hood. I looked for any wires burning but didnt see any. Just as I was slamming the hood shut I noticed some blackened pipe dope where my coolant filter is. Closer inspection revealed that the positive starter cable had chafed against the ball valve and melted halfway through the cable. I pulled that battery (passenger side) out and wrapped the lug and cable with my cup holder/ duct tape. I couldnt get her started with the weakened cable and only one battery. not even running jumpers from the other battery could crank her fast enough. Luckily a nice man in a 2000 F-250 PSD pulled in and gave me a jump. THANK YOU!!!!! Well I guess its time for new battery cables!! Cha Ching! About two years ago I wrapped my cables in a lot of tape and I think its time to bite the bullet and buy some new ones. I am just thankful that I made it home safely and no damage was done to Big Green.
Instead of the straight through design for the positive terminal on the passenger side is there a way I can get a right angled terminal? This will direct the cable away from the filter plumbing.
