bajabomber87
I'm not sure if anyone has done this here yet but I thought I'd post about my setup I will be installing/fabbing.
The truck is a 91 F350 CC w/7.3idi and a zf-5.
I bought a 093 wastegated ATS turbo system from Discbrks here on the board. He was very thorough with his instructions and cleaned almost every piece I would need to do the conversion so
to him
I came across the silicone intakes website from searching on here, and after doing a little searching and finding out their intercoolers were actually mentioned in a diesel mag I figured why not try them?
Now what makes my setup different from most on here would be the fact I'm going to do a water to air
? maybe...
Water to air kit: http://www.siliconeintakes.com/prod...=1006&osCsid=625235cc6015ead488b0f40574e3d019
14x24" radiator and a 10" cooling fan.
I also upgraded to the Bosch pump instead of the cheaper "ballast" pump they include.
I have all the couplers, clamps, coolant hoses and clamps coming too.
I plan on rotating the compressor housing up and using the "air hat" included in the ATS kit. All I'll be doing is turning it around so it will point towards the intercooler as much as possible.
Ive read and read about the crushed down tube on these trucks and it is absolutely the dumbest thing Ive seen. There is about 1/2" space for the exhaust to pass thru?
So to fix that I've got some 3" tubing on order at the fab shop so I can build my own 3" down pipe.
One question on that, why is the turbo inlet pipe crushed too? Does that hamper its flow at all? I can fab up a new inlet and flange that isnt crushed but I'm just not sure if 1) its worth it and 2) will a fully circular inlet pipe fit behind the block and the firewall?
Then after the 3" down pipe I will be doing a 4" exhaust all the way back, possibly a single, short black stack.
And I'll be getting these gauges but the tranny temp sensor will be used for keeping track of the intercooler coolant temp.
http://cgi.ebay.com/ebaymotors/ws/e...0384816704&sspagename=STRK:MEWAX:IT&viewitem=
Once I can get my truck to my house (awaiting a new front 60) I will immediately start posting pics, I know I know, pointless post without pics! but I need some of my questions answered first so I can make this install as smooth as possible.
Tyler
? maybe...Water to air kit: http://www.siliconeintakes.com/prod...=1006&osCsid=625235cc6015ead488b0f40574e3d019
Tyler
(if mounted away from the cooling system)
