Metalmacguyver
We still have our ranger, but it eats diesel now
Care to elaborate on that?
And does anyone know if D50 brake parts will work on a D60?
yes they should.And does anyone know if D50 brake parts will work on a D60?
yes they should.
knuckles should be the same if it's ball joint design.
Its got a 2.3L turbo diesel now, 4cyl overhead cam made by mitsubishi. It was offered in both the dodge ram (rebadged mitsubishi mighty max) as well as the ford rangers in the mid 80s. Its called the 4D55-T, its descendant is still in production to this day and they are the workhorse of south east asia.
We bought a 1985 ranger donor truck from a wrecker that had the engine, I had to rebuild it, then swapped it over. All rangers of that era used a mitsubishi transmission of one type or another, so the bellhousing from the donor fit the transmission that was in our truck (the donor was 2wd so we couldn't use it).
Very nice little motor and it has comparable perfomance to the 2.9L EFI that it replaced. It uses the bosch VE rotary injector pump and it can make lots of power, but I'm too scared to crank the fuel up for fear of lifting the aluminum head. Stock rating is 86Hp, but the new rollercam head I put on last year probably brings it in the mid 90s. I'm sure it actually has less max power than the V6, but the powerband is such that you only notice the difference if you try and go past 80 MPH (which it will do, BTW)
Its actually my sister's truck, but I joke about saying that its MY engine. I saw a ford exploder with a cummins 4BT once, but the nice thing about this engine is that it matched the weight of the 2.9 so no suspension mods were needed.
if you have access to the truck, you will need the springs and the track bar mount on the frame. the D50 springs are arched the wrong way and the track bar mount is a SOB to find.
the IFS springs are reverse arched. they're not intended to support the entire weight of the truck, the pivot point shares some of the load.Towcat do you mind elaborating on the front springs being the wrong way. I did the swap using my original 44 springs, and increased the ride height in front roughly to the same height as other f350's around here. What I do need to do eventually is scrounge up the rear f350 spacer blocks to level out my pickup. Which is something I recommend you go back and get metalmacguyver. And a bag of ice for the kidneys.
And ditto on the track bar mount, I got freaking lucky that a friend was doing a shackle reversal on his, and no longer needed the oem mount.
