So currently the van has a 3.55 gear in the rear dana 60 differential. The tires I have on the van are 245/75/R16. Tread is still fairly new so that gives me a diameter of 30.46 inches on the wheel.
Using the gear ratios for the E4OD from Gear Vendor's site
https://www.gearvendors.com/fdrive.html
and putting all the data in to here
According to this website
https://spicerparts.com/calculators/transmission-ratio-rpm-calculator
It says my engine should be spinning 1950 RPM at 70 MPH with the 3.55 gears and stock overdrive ratio of 0.71. I guess that's about right, my tachometer says otherwise but I think it's a little off. The math on the spicer site should be correct as it's, well... math.
Anyway, if I put the Gear Vendors on right now with the 3.55 gear and the new double overdrive ratio of 0.55, my RPM would drop to about 1500 RPM at 70 MPH.
According to our engine specs, we make peak torque of 338 ft-lbs @ 1400 RPM and the torque curve is relatively flat as RPM increase.
At 1950 RPM the engine should max out at around 120 HP, at 1500 RPM the engine should be able to put out 94 HP. Problem is I don't really know what HP I need to keep rolling at 70MPH on a flat road. I'm guessing it is maybe somewhere around 50-60 HP but i might be completely wrong here. So it seems this might work ok...?
However, I was now thinking to increase towing ease and maybe help performance overall, I would switch the rear gears to 4.10 and then install the Gear Vendor. That would put my cruising RPM at 1750 with the double overdrive. Max HP there would be about 108 HP.
So question is, do anyone have an idea if cruising at 1500 RPM / 94 HP is too low? Will I get bogged down too easy?
Using 4.10 gears, the 1750 RPM / 108 HP would give me a little more HP over the 3.55 and still give me a savings of about 200 RPM at 70 MPH so I'm guessing a good bump in fuel economy too.
Any opinions?
Thanks.
"When a car moves along a flat road the engine has to work to overcome two main resistances - air resistance and rolling resistance (the drag in tyres, wheel bearings etc). The top speed of the car is determined by the amount of engine power available and the size of these retarding forces. The math to work out these equations for an actual vehicle are very simple. In order to calculate the top speed we need to work out the size of the retarding forces.
ROLLING RESISTANCE
Defined as the force needed to just start a car rolling on flat ground this force is mainly a function of vehicle weight. You can measure it yourself fairly easily with a pair of bathroom scales or a spring balance. Just hold the scales vertical against the rear bumper and push until the car starts to move. You might find that once the car is rolling the force needed to keep it just moving falls slightly. This lower force is the number you are after. For most cars the force in pounds can be estimated as follows:
Rolling resistance (lbs) = vehicle weight (lbs) x 0.012 to 0.015 (I usually take 0.013 as a good average)
Obviously if the tyres are flat or a wheel bearing is half seized this force can alter a fair bit but we will see later that it is air resistance that is the main obstacle to top speed so even a large error in the rolling resistance calculation won't matter much. Rolling resistance is taken to be a constant i.e. not varying with vehicle speed although this is really somewhat of a simplification. For an average car weighing 2500 lbs this force is therefore in the region of 33lbs.
AIR RESISTANCE
This is a function of the frontal area (fA) of the car and its coefficient of drag (Cd). Often car magazine tests show these numbers and all manufacturers will have the data if they can be persuaded to release them. Most modern cars have drag coefficients between 0.3 and 0.4 with a few really streamlined ones as low as 0.28 or so. The Cd is a measure of how "slippery" a shape is as the air goes round it.
Frontal areas tend to lie between 19 and 23 square feet for European cars (we can exclude 4 wheel drive yank tanks and similar from this exercise because who cares how fast they go anyway?)
The drag in pounds goes up with the square of speed and can be calculated from the following formula:
Air resistance (lbs) = fA x Cd x 0.00256 x speed squared (speed in mph)
Average family cars have a top speed of 120 mph or so these days so let's have a look at the size of this force at that speed. We'll assume the car has a frontal area of 21 square feet and a Cd of 0.35
Air resistance (lbs) = 21 x 0.35 x 0.00256 x 120 x 120 = 271 lbs (at 120 mph)
As you can see this is a much larger force than the rolling resistance. In fact rolling resistance only makes a major difference to vehicle dynamics at very low speeds (under 60 mph or so) and means that heavy cars use more power and therefore have poor fuel consumption at low speeds. At higher speeds the air resistance becomes paramount and so even heavy cars can show good fuel consumption if they are well streamlined.
POWER REQUIRED
The final step is to relate the drag figures above to the power required to overcome them. If we add rolling resistance and air resistance together we get total drag in pounds. Power required is then calculated as:
Power (bhp) = Total drag x mph / 375
We could if required split the power into the amounts needed to overcome each drag separately. The equations would then become:
Power to overcome rolling resistance = weight x 0.013 x mph / 375
Power to overcome air drag = fA x Cd x 0.00256 x mph cubed / 375
Hopefully something of major importance should be clear from the above. We already know that it is air resistance that is the major element in this equation and we can see that we need to incorporate mph cubed in the power equation for air drag. As a simplification therefore we can say that power required is closely related to mph cubed - i.e. to double the speed of a vehicle we need 8 times the engine power. Alternatively we can express this as top speed is a function of the cube root of engine power. This means that engine modifications will have a much greater impact on acceleration (which is directly related to power) than top speed. Also that is why an old engine which is down on power might accelerate slowly but still have close to its original top speed. So next time your mate tells you in the pub that he put a K&N air filter in his car and the top speed went up by 10 mph you can explain exactly why that isn't going to be very likely.
Examples:
Let's say we want to increase the top speed of a car by 10% - how much extra power do we need? Increase in power required is related to increase in speed cubed - i.e. to 1.10 cubed = 1.33. So we need about 33% extra power to achieve 10% increase in top speed.Alternatively let's say we tune an engine and achieve 10% extra power - how much will top speed go up by?. Speed is proportional to the cube root of power - i.e. to the cube root of 1.10 = 1.03. So speed will only increase by about 3%.
What this all means for you hopefuls who bolt on go faster goodies like chips, exhausts and the like. You will see hardly any increase in top speed. To get significant increases in top speed requires serious engine surgery.
IMPORTANT NOTE:
The power calculated above is power delivered to the wheels and NOT flywheel power - i.e. we need to allow for transmission losses to get back to engine power required. Transmission losses will be the subject of another article but for brevity we can take the following as good assumptions. Front wheel drive cars will lose 15% of the engine power as transmission and tyre losses and rear wheel drive cars will lose 17%. This assumes manual gearboxes and I could care less how fast autos or 4 wheel drive cars go !
So divide by 0.85 or 0.83 as appropriate to convert from wheel bhp to flywheel bhp."
Cant find any drag coefficents for an econoline. Buses are .6-.8, trucks (I assume tractor trailer) .8-1.0, so perhaps .8 is a reasonable guess. Based on 80" wide, 84" tall (per wikipedia) frontal area = ~47 sq ft (assuming flat faced, no idea if thats correct), 6500 lb van, .8 coefficient of drag, we get 112 hp @ 70 mph. This seems overly high, so I would think my guesstimates are off quite a bit.
EDIT* Apparently frontal area is usually max width x max height x some factor (I suppose this would take into account area under the grille, slopped front glass etc). A .85 factor here would bring down HP to 92-93 hp @ 70 mph.
