1994 IDI Turbo Crew Cab 2WD Complete WMO Project
TestDriver
Howell, MI
Selling my project truck along with all my acquired/fabricated WMO stuff. The truck runs but has developed a head gasket leak and I'm not in the mood to fix it. Here is a link to my youtube channel with various videos of it:
https://www.youtube.com/channel/UCvvsvpol36PJxVHw57aYHnQ
The truck is not nearly as clean as the 8 year old video shows. But, it's still all there with marginally more miles and some improvements. There are other videos that show it currently running with the head gasket leak. Here are some related specs:
Pacifica Conversion with;
  • Bench front seat with fold down center
  • Lund fender flares, visor with clearance lights and fastback rear fairing
  • Overhead console with CB
  • Various interior wood trim appliques
On-board Spinner II centrifuge that can be better explained in this thread;
https://www.oilburners.net/threads/my-on-board-centrifuge-setup.48004/
120 Gallon in-bed tank
Front factory tank heater, seen here;
https://www.oilburners.net/threads/tank-heater-installed.35498/
Included will be;
In-bed tool box to go above in-bed fuel tank
Various IP spares and parts
2 sets of injection lines
Van fuel filter base
Spare new vacuum pump
Various (maybe 12) new oil filters
Several new fuel filters
Home-made injection pop tester along with adjusting shims
Several spare/rebuildable injectors
325 Gallon cube
300 gallons used motor oil
The 120V transfer/filtering setup I built
There's probably a lot I have overlooked but I'm not near it now. When there next, I'll do further inventory. The truck has fresh batteries, starter, rebuilt pump (NA) and injectors. But it also needs a brake line replaced before driving and possibly front brakes. I have new pads that can go too. It will need to be towed or trailered out of here. Also, there is about a ton of scrap metal in the bed. If you want it, it can go too.
The truck has sat still for some 6 years and it's not much to look at on the surface. I recently went about resuscitating it when I found the head gasket leak. Otherwise, I would have cleaned it up. But, like I said, it's all there from the nice looking video of 8 years ago.
Post here with questions and I can PM I want $4000 for it all. Time telling, the price might change.
Thanks.
TestDriver
Howell, MI
I could get some in the coming days. But, like I said, it's the same as the video I posted. Only, it's covered in shag bark hickory "patina" right now.
mydixiewrecked
Staff online
