carid
If you're looking to enhance both the functionality and style of your pickup, Air Design offers a range of premium accessories designed to meet your needs. Their Super Rim™ Fender Flares provide robust protection against road debris while adding a rugged aesthetic to your vehicle. These flares feature a mechanical fixation system that ensures a secure fit, eliminating vibrations and potential paint damage. Additionally, the integrated mud flap contour at the bottom helps prevent splashes and protects the sides of your truck.
For those aiming to improve engine bay ventilation and aerodynamics, Air Design's Fender Vents are a practical addition. These vents facilitate the extraction of hot air from the engine compartment and reduce high-pressure air buildup in the wheel wells. Beyond their functional benefits, they also add a touch of elegance to your truck's exterior.
To further personalize your vehicle's rear end, consider the Super Rim™ Tailgate Spoiler and Tailgate Applique. The tailgate spoiler enhances aerodynamics and provides a distinctive look, while the applique offers a premium-sport upgrade without the need for drilling. Both accessories are crafted from high-quality materials, ensuring durability and a perfect fit.
Explore these and other Air Design products at CARiD.com to find the perfect enhancements for your truck.
Air Design® - Super Rim™ Fender Flares
Super Rim™ Fender Flares by Air Design®. At CARiD.com you can find a comprehensive line of Air Design replacement and performance parts and accessories which ensure reliability and superior performance.
Note: Select your vehicle when adding to cart to confirm fitment
Features:
- Mechanical fixation to the body line, to eliminate all vibration and paint damage
- Mud flap "anti-splash" contour that widens the bottom of the flare, protecting the sides of the vehicle
- Advanced aerodynamic mud flap integrated into air design fender flares, stops rocks and road debris from chipping you vehicle's paint
- Parts are molded using high-tech multilayer black ABS senosan polymer and top coated on their surface for extra UV protection and strength using a German OEM approved 2k satin black paint
Air Design® - Fender Vents
Features:
- Made to accessorize your vehicle and give it a stylish upgrade
- Help reduce high pressure air that builds up in the wheel wells
- Will aid in providing additional cooling to the engine area
- Crafted from superior-grade materials for enduring service
Air Design® - Super Rim™ Tailgate Spoiler
Super Rim™ Tailgate Spoiler by Air Design®. Visually and Technically, the elegant design on every Pick Up Tailgate Spoiler by Air Design provide a unique level of personalization and improved aerodynamics.
Features:
- Provides unique level of personalization and improved aerodynamics
- Visually and technically, offers elegant design
- An outstanding premium-sport rear end upgrade
- Installs on the rear door of your truck in matter of minutes with perfect fit and no drilling is required
- Expertly manufactured from the highest grade materials
- Made to guarantee exceptional reliability
- Will provide a reliable solution for off-road applications
Air Design® - Super Rim™ Tailgate Applique
Features:
- Smart way to individualize and restyle your truck’s rear end
- Manufactured applying Air Design’s Super R.I.M. technology
- Ensures outstanding reliability and incomparable quality
- Provides a precise fit that makes installation a cinch
- Beef Up your Truck. Improve performance and appearance
- Quality Materials. All components are manufactured out of high impact multilayer ABS
- Extra Protection. Provide added protection against road debris, mud and chipping
- Easy to Install. Automotive grade adhesives make this an easy and long-lasting installation
- Rust Free. Install without drilling a single hole on the Sheet Metal. Forget about rust and those unwanted gaps!
- Removable. Can be easily removed to return your Truck to Stock condition
- Factory Painted: Satin Black Finish, Install Ready. Factory applied OEM UV Stable Satin Black 2K German Paint Finish
- This finish will prevent any premature color fading or material cracking due to the harmful rays of the sun
- Factory applied industrial 2K German primer
To learn more about the Air Design brand, go to the page below:
