ZF5 Speed is in the truck!
TorchMadness
Lakeland
Alright folks after finally accumulating all the parts for my conversion from a c6 to a ZF5 transmission I finally got the bad boy in. Now how in the heck do I get a good pressure on the shift fork to pop it into place!? All that is left to do is install the slave cylinder, clutch fork and drive shaft. Any suggestions on the fork
TorchMadness
Lakeland
shift fork? as in transmission internal?
It's the shift fork that the slave is touching to push the clutch free during shifting.... Sticks out the side of the transmission. It was already installed on that video.
That is clutch fork...it usually best have it installed when you bolt up transmission..
It can be a ****** to get set right otherwise...
olsen726
