ZF5 inspection cover NEEDED
geonc
SPIDER BAIT
NECKVILLE North Carolina
Are you referring to one of the side covers?
If so Any PTO [power take off] cover from any trans--auto or std- will work so I'm sure your local boneyard, towing shop etc should have a great selection.
$10 or a sixer of some cold barlypop should set you up :D
No worries on a gasket...a decent bead of RVT will suffice.
Be sure and double check the threaded holes---"some" will be thru drilled and require thread sealant as these are meant for studs to mount hyd pumps.
I'd be willing to bet he is wanting a FLYWHEEL inspection cover. ;)
91crew
San Luis Obispo, CA
Agnems right, I need the flywheel inspection cover before I fill my clutch up with sand at the dunes next weekend.
1994Diesel
Constantly thinking
Central coast, CA
Hey 91crew, there has got to be one down in santa maria at the black road auto junk yard. I saw a few t19s there a while ago, and i thin one zf5.
Id grab one for you, but im outa town right now.
91crew
San Luis Obispo, CA
Justin,
I scrounged through all the nipomo mesa junkyards last weekend and there weren't any there. Thanks for the offer.
1994Diesel
Constantly thinking
Central coast, CA
Justin,
No problem.;Sweet
yea, the ones on the mesa arnt any good. The one in santa maria has good stuff, you just have to deal with there outrageous prices, and try to talk them down.
EMD_DRIVER
Say what?!?!
Beaufort, SC
Will one off a zf5 from behind a 460 work?
That's what I used for mine, but had to cut it down. The bolt holes won't line up. The only part I used, was the bottom part that mounts to the tranny. I couldn't find a diesel one, when I did my swap.
Bradz
