ZF5, Bans Turbo,1356 T-case, Hydrboost, Vacuum pump & Misc
jaluhn83
Upper Marlboro, MD
1) ZF S5-42 4wd - sold for $500.
2) Banks WG turbo. This turbo has an interesting history. It works but has a unique quirks. I bought it off ebay some years ago as a "new" unit. It did appear brand new and had never been run, but it was also incompletely and as a I later found had a problem with the wastegate valve seat. (hole in the casting was bigger than the valve disc - cookoo) I was able to repair the wastegate issue with a machined seat insert and fabricated a wastegate actuator and heat shield for the turbo to make it functionally equivalent to the OEM unit. In service it performed well, but seems to make less than expected boost - ~5-6psi @ 2k rpm / 8-9 @ 2750. This is still enough boost to make good power though. My suspicion is that the exhaust housing is not right, probably too large of A/R.
I would say the best use for this unit would be a center housing assembly replacement for a worn/failed turbo - I strongly suspect that th proper exhaust housing found fix the low boost issue I had. Alternatively, it did work well in it's current condition.
The unit was removed to upgrade to a HX35.
$250.
3) Slip yoke styple 13-56 t-case. Used unknown condition removed from a junkyard truck. I expect it's in good shape and usable but I can't say for sure. Was bought as an emergency replacement for the truck but I never used it due to driveline issues.
$100.
4) Used hydroboost/1 5/16" master cylinder assembly. Removed from a junkyard F-superduty, appears to be in good shape. Includes the brake line adapter fitting and hydroboost to steering box hose.
$125
5) Homemade turbo intake hat - built from a steel pipe cap with a 2" nipple welded in. Worked well with my homebrew turbo setup but a bit oakie looking. I also have the turbo to hat pipe, but it'd only be useful with a similar homebrew setup.
$20
6) Good used vacuum pump with pulley. Removed due to hydroboost conversion but worked well before. I *think* this was a new replacement unit ~5 years ago but can't remember for sure.
$50
7) Good used vacuum brake boost unit & ps pump.
$10 ea
jaluhn83
Upper Marlboro, MD
I'm not 100% sure but I think 92? There were 2 trucks I pulled parts off of, one was a 92 or 93 and the other 88? Not 100% sure which one the hydroboost unit came off of.
Is there a difference? I was under the impression that all of them up to 97 were the essentially the same.
Seven4eight
