ZF5 advice ?
typ4
Newberg,OR
the valeo clutch should help the noise some. The takeoff noise will always be there if lugging
pt_Ranger_v8
Vegas
Why do you have to use a SD x-fer case with a ZF-6? Is the output different than the standard 6-bolt pattern?
idipwr
Ohio
Bolt pattern is the same, just the shaft size and spline count is different.
Exekiel69
If You get rid of the zf in favor of a nv4500 I want first dibs on the engine adapter :sly.
RLDSL
Diesel fuel abuser
Arkansas
If instead of that valeo clutch you call Ft Wayne clutch and get a 12 1/4" solid flywheel and one of their kevlar clutch kits to go with it, you will get about 9 springs in the hub of the clutch and a very smoothly engaging clutch facing. THen fill your box with synthetic 50wt atf and you will barely notice the thing is there
alienturtle
Human
Ripon, CA
haha i think i am going to keep the zf in here. but if i ever do you will be the first to know.
Well i already have my Valair clutch sitting in my room. I purchased this one right here. Im hoping it will last me. Its got 8 springs in it so we will see what happens. I was told they were good clutches.
12.25" x 1.25" Stock Organic Replacement
Premium Brass Woven Organic Facings
HD Spring Hub
Rated @ 400HP /850 ft lbs Torque
3800# Pressure Plate
Kit includes: Pressure Plate, Clutch Disc, Release Bearing, Pilot Bearing and Alignment Tool.
Bradz
