YOU SEEN THESE??????
Tinman875
Caldwell, id
HEY GO HERE -----> injector nozzles
AND TAKE A LOOK. I EMAILED THE DUDE, AND HE SAID THEY ARE MACHINED NOT LIQUID DRILLED( MY BEST WAY TO DESCRIBE IT)?? WHERE THE OTHER INJECTOR MAKERS USE A ABRASIVE LIQUID TO BORE THE HOLES IN THEM, THESE ARN'T. NOT A BAD PRICE FOR 140HP NOZZLES.
or would these be better -----> BOSCH :cheers:
2500cummins
Not far enough from Vegas
The Bosch injectors in the second link are usually called "275 hp RV" injectors, the same injector is used in the emergency service 300 hp ISB engine and the 275 hp RV engine. The 275's give about 30 hp in an ETC and 5 to 10 hp more in an ETH engine.
I dont have a clue about the others, he called them "Jammers" once, thats what Diesel Dynamics calls their latest tips.
Tinman875
Caldwell, id
mabey they aren't so bad. ebung said that stages 1-3 is the way to go, and that is what the dude on ebay said. He prefers the stage 3 for everyday driving/towing. Ill look into it more.
MLR
Shelley, ID
Those are the same as the Edge (Diesel Dynamics) Jammer nozzles. You can buy them HERE or HERE cheaper and from an actual dealer.
HTH
Max
Tyler9828
