dank1945
Hippo Hands man
Hi all,
I went to check out a 96 2500 today, and I'm not sure if I'm looking at a 53 block or not. Up at the top of the block, close to the front cover, driver's side, and almost hidden under a large bracket that holds fuel lines in place, I found in large raised numbers a "53", with a space and a series of other numbers following. Is this the infamous 53 block? Is it possible to have a 96 with a 53 block?
Also, does anyone know the difference in hp from my 94 F350 CC 7.3L IDI to the 5.9 L Cummins? This 96 only has about 130 k miles on it, seems to have been well taken care of body wise, tranny repaired 2 years ago. It definitely needs a new rad, this one's fins are desintegrating. Rancho shocks, air bags, good interior, and impecable exterior, aluminum wider rims, and OEm rims, two sets of tires. Asking $10,000 US.
Opinions or suggestions encouraged, please!
Thanks,
Dan
Thanks,
Dan
