WVO and cleaning system
fields_mj
Brazil, Indiana
I have 300 to 400 gal of WVO that I need to get rid of. Must take it all. Most is in a 275 gal IBC tote. I can supply 55 gal poly or steel drums to put it in for $20 each. You're welcome to the tote as well. I have 2 more IBC Totes also available. I can pump into a tote in your truck or trailer. Pump will fill/empty a 55 gal drums in 15 min. Oil and totes are free. I have a loader that can pick up the totes when empty.
Also have a home built centrifuge available. Uses the PoBoy bowl and feed head. I think it has a 3/4 hp motor, but can't recall. Bowl mounts to motor shaft with a collet, so very easy to remove for cleaning. Has 1200 watt heater with thermostat on the feed. I generally ran 100 gal in about 8 hrs. Asking $300, but will consider reasonable offers.
fields_mj
Brazil, Indiana
Yes and yes-ish. The pictures I have are from when I built it, but I can go snap a few pics if you like. Just let me know where to send them.
Booyah45828
Ohio
My cell works for me if it does for you.
419-eight-five-two-5390
Or you can PM me here.
Tyler9828
