Would you reuse it?
bbjordan
Snow Monkey
Ashern Manitoba
This is the pressure plate that came with the '97 F250 I just got. The fingers look worn enough to make me feel a little uncomfortable with reusing it. What does the collective think?
Seems a little worn.
At this point I'd replace it while it's out.
I bet the po rested his foot on the clutch.
greenskeeper
PA
I would personally change everything out related to the clutch change while it's apart. Unless you are tight on funds or can do the r/r yourself...what a hassle especially if 4x4.
Clb
Another old truck
nannyfornia
Rear mainseal also, that pp is havoc awaiting an occurrence!
Lol I like that answer.
I wouldn't touch the rear main unless it's leaking.
They don't seem to be that big a problem with the powerstrokes.
Only got 183K on mine. Since I've been under the truck with the 4WD problem, I see my rear seal is leaking. Thought it was the orings on the HPOP lines just leaking and running down the rear. Gotta get those lines changed before they blow.
