Pull-n-TugTx
Had issues with the rear tank empty at 1/4, front tank running sluggish, and sputtering with fuel light on. Pulled the rear Sending Unit put on some fuel line for the shower head. Still had the same problem, that day! Noticed the tank was leaking at the Sending Unit seal Ring. Re-set with new ring and seal, Fixed. Couple of days later, it wouldnt start. Turn over, but no burn! Replaced the filter, had to jump the batteries, fired up and drove it home. Next day NO START!
Fulled the line of at the the filter. No fuel coming out. PUMP?! Replaced the pump and still won't start. Do have fuel coming out at filter. Pulled an outlet line from the Injector Pump, NO FUEL!
Am I headed in the right direction or am I missing something?? Also, pulling the IP. Do I pull the oil fill neck housing with it, or just take the 3 bolts from the inside on the gear inside?
Get a New pump, Re-built, or Rebuild the one I got?
All help greatly needed!!
