Woah woah woah, I'm on fire...
Wyreth
Certifiable Noob
Las Vegas, Nv
Trying desperately to move from Sac to Vegas aaaannnd..... I was dumb! cookoo Overloaded my 87 f250 past the point of absurdity. Then, well then, in grapes of wrath fassion. Headed off on my way. Hit the Tehachapi pass, and scattered the trans. Caught fire briefly even.
Truck still runs but, now I need a c6 I can afford (read $200 and under range)
Anyone in the Tehachapi - Vegas area got one they'd sell? Or...
Can I modify the bellhousing from the 460 c6 to fit the 6.9 like you can with the zf? If so what do I need to do? And are the spline counts different?
ocnorb
IDIT
Wasatch Front
Only the good die young...
Not much help with the C6... I have a 2wd ZF5, flywheel and clutch included for $300.
Wyreth
Certifiable Noob
Las Vegas, Nv
Much as I would love to take you up on that, I simply do not have the time to change it over to manual. Luckly DragRag hooked me up with a c6 That I hope to have installed Sat.
However, if you still have that setup in January when things settle down after this move, I will take you up on it.
lewisstevey7
