So i had no blower fan, i get voltage at the blower plug but there is nothing on the orange/black wire which should be ground when my wife cycled the switch. I added an aux ground to test it as you can see in the pic, just tapped that onto the battery negative terminal. The blower fired up, but the issue is that it is only high mode, i cant get it to cycle to lower speeds. The resistor in the air box is good. Again, I am dumb electrically..any idea where the issue may be?
If you follow that orange/black wire, in the engine bay it splits to the blower resistor, and then inside the cab it runs into the function selector switch (off, ac max, defrost etc). I have tried two sets of switches as well to rule it out (and i know mine worked before this massive rewire job, so obviously I messed something up)
