Wiring diagram (schematic 7.3)
fraree
Inland. Australia
Searched on here, searched outside here, cannot find a colour coded diagram anywhere! Need Help.
fraree
Inland. Australia
PSD 7.3, 2000, 2wd. The air conditioning section. The reason- I have an ex ambulance with a separate A/c unit in the rear, which we have disconnected the gas piping to decommission the unit. Upon regasing, with the new shorter piping, the compressor won't switch on (does with a jump wire OK) While checking connections on the left front inner guard the fan (blower) stopped running. Used a jump wire from the blower relay, now blower works. So, we need to know where the malfunctioning wiring, connection, extra fuses maybe. Thanks Russ
fraree
Inland. Australia
Finally found a download copy of the workshop manual for my truck.:Thumbs Up In a bit of luck, I had a $10 voucher on "evilbuy" so the download was free, bonus :D Now to look up the relevant section but I still think there'll be some kind of "tie in" with the rear unit causing grief. o_O
Jason1377
Arkansas
Can only assume evilbuy = eBay
Another place you can look is called alldata since some auto part stores no longer sell manuals.
fraree
Inland. Australia
Cant just find the EVTM setup anywhere. Bought the "manual" but it's a nightmare.
It appears this stupid vacuum setup has something to do with the issue so I'll go through all that piping, no wonder the wiring wasn't helping.
There are only a handfull of people in this whole country (Australia) than know much about these trucks, so we get really "snookered" when we run into trouble with them & parts availability, there's another issue :mad: Really starting to turn me off these Ftrucks !
fraree
Inland. Australia
A bit of success today, blower motor working, so solved half the vacuum issues.;) Still looking activate the compressor. Dash out again in the morning :(
fraree
Inland. Australia
Thanks but the trouble with living in the southern hemisphere most part/online stores aren't interesting in dealing let alone sending anything outside the USA. Just a fact of life, living in the best country in the world, Australia.
fraree
Inland. Australia
I don't know about "the best country in the world," but it's been my lifetime goal to go to Australia before I die!!! LOL LOL
........hummm, I better hurry up!!! LOL
BTW, good luck on your A/C problems!!
Just about beaten the A/c problems. Beep tested wires after we had the vacuum lines tested
& sorted. Found a wire from the low pressure switch which must have a break. Half the issue is with the left to right hand drive conversion.:mad: The receiver drier is moved across to near the LH headlight & airbox intake, evaporator is next to the airbox on the firewall too, so new wires are run (extended). So after nearly 20 yrs service once they're disturbed (radiator & intercooler removed & refitted) right where these wires run with joiners, there's going to be an issue. As there's no recorded plan for these modifications it's been a very frustrating "learning curve" to track down where things go, differing from the factory. Just about on top of this now.
Back to Australia, "the best country in the world"- Even our worst beaches makes Waikiki look second rate. Our climate, 90% of the year is shorts & short sleeves & best of all, our kids can go to school without the fear of some F'wit with an automatic weapon gunning them down !
fraree
Inland. Australia
Solve one problem & another one pops up ! Now my batteries are going flat in 2 days & the headlight chime/beeper is not working. So I suspect, since we've pulled the dash half out, checking the A/c vacuum lines something has come loose there :frustrate This truck is starting to act like my previous '89 :dunno
720Diesel
