plywood
Recovered N/A
I'm guessing the plastic bushings in there in that video based on the design of the large white gear are for cushioning so the window glass doesn't get broke.
I just bought a reman motor and realized it probably just needed those plastic bushings which appear to be available on Summitracing for only $13.99 with the big white gear for at least some Fords.
For reference I am working on my 88 Bronco II and for the driver side it would stop at the top and not work on occasion. I would remove the motor and it would work fine but had a stutter in the motion. Only takes two 10mm nuts and to get the motor apart at the Electrical end. Found it looks like some of the grease from the end bushing got into the armature and caused a breech. So after cleaning it runs smooth. Question is if the bushing was going bad and therefore heating up the grease in which case I may have to replace anyway.
