Winch bumper
and guaranteed to bend and tweak, the first time you use it.
Dieselcrawler
Professional wrench holder
Staff member
Quakertown Pa
that appears to be a older warn bumper with extras welded on. Same as mine
with enough filler rod grinding discs torch and metal it'll Fit just fine.
based on angles of side plates on top it looks more like obs style....but who knkws....
make it fit.
my "winch bumper" was mostly 1/8" and the brackets were 5/16 plate to the bumper. I sold it,
12k # can produce a lot of torque.
but I wouldn't want 4 or even 6 bolts, even grade 8 to trust pulling my rig out of a rut.
I mounted my winch to the frame when I did my custom bumper.
I tend to overkill a lot of situations.
my winch bolts to a 1/2" plate, that's welded and gusseted to a front crossmember I installed on my truck for a reverse shackle kit.
heavy fabrication required.
DOE-SST
1994 E350
USA
I bought that winch. the cable was garbage. first time I used it I found it wasn't flexible enough to coil correctly back onto the spool. While retracting it, the cable bound up and mangled itself. keep the winch fully protected from water or it will be junk soon.
Dieselcrawler
Staff member
Quakertown Pa
Cable is about 25 feet to long on them. And my 12k badlands was been abused and dunked many times, never hosed it out and never had a problem
KZF250
Denver
Definitely too long and has to be spooled back on just right or starts rubbing. I quit freeing the drum to spool out and just reverse while keeping tension...I don't use it for four wheelin tho, just to load cars so I don't have to pull much out.
morerunner
