Will these fit?
Fishin76
Canton, IL
I found on CL, a whole set of (4) 16.5 x 10 8 lug wagon wheel rims. Can i fit those on my F250? How wide of a tire can i fit, and what is the minimum needed to put on those rims?
I'd pick them up if they fit, only $35...
91f2504x4
KY
It depends on what lug pattern they are, if they are 8 on 170 or 8 on 200 then they will not fit, but if they are 8 on 6.5 then yes they will fit. a 10 inch wide wheel can handle a 12.50 wide tire just fine, some people even run 14.50s on them. With a stock height F250 4x4 a set of 33x12.50's look good on there. But check to see how much tires are going to cost for them first and if they can be had in your area. Some people have trouble finding 16.5 tires.
Pretty much if they are off of a Dodge or Chevy 8 lug or an older ford (but not a superduty) then they will fit your truck.
JU57US
