why would truck overheat in the cold?
noahz
92 F250 idi
tulsa
I have 7.3l. its somewhere around 15 degrees and it all of the sudden started to overheat and then the radiator started leaking boiling water.... what are your thoughts...?
Jake S.
clueless...
Taylors Falls, MN
Or antifreeze thats not good enough. It has a tendency to freeze in the rad. as you drive down the road. The hot boiling water comes from the upper rad hose, and cannot flow through the rad.
69oiler
I don't feel tardy
Chardon OH
yep. my bet is frozen radiator. better get some antifreeze in there pronto.
NJKen
is a daddy!
Central NJ
freezing in the fins kinda stuck out to me too since it never happened til it got COLD.
Ken
dyoung14
Is getting worn out
spencer,tn
yes thats how my gran pa ruined his flat head v8 that was in his 53 ford he didnt have enough antifreeze in it and it froze and busted going do the road, and it cracked the block:eek:
JesterPgh
Baden PA
I just had this happen to me the other day with my 6.9. I thought it was awfully odd, and luckily, I was near a parts store. Knowing my antifreeze was up to *****, I took a shot at the old rad cap being worn. New 13lb cap, and hasn't happened again.
dakotajeep
Patrolling
TN/ND
Pretty cold up in Winnipeg right now for sure.....its supposed to be -30F here in Bismarck tonight.....
Yeah, probably froze the fluid......
Thad
mankypro
Learning Slowly...
Boulder County, Colorado
It's -6f here - I run 2/3's green prestone and 1/3 distilled with two bottles of fw16 - I had the overtemp light come on the other morning - pretty sure it was due to ridiculously cold temps. Had my reverse lights on for a while while in 1st gear too.
Man it's goram cold.
mankypro
Learning Slowly...
Judging by this guys comments I'm going to assume an IDI is up to the task if properly cared for. ;Really
ntjapkes
