Where to get speedometer gears?
KansasIDI
Hopelessly addicted to IDIs
Wilsey, KS
I cannot find where to get the 7 tooth worm gear that slides onto the output shaft in my transfer case. The one that is in there is all mangled up.
You probably have a BW 13-45 transfer case. I had enough problems with that gear in mine that I quit even trying and use a universal GPS driven speedometer. I love it unless I want an odometer. Then I'm out of luck.
The_Josh_Bear
Western WA
I got mine on eBay. There are sets as well as single units depending on the color you need
Same here, I was really suspicious about quality but they ended up being fine. Comes in a 5-pack which I thought I would never use, but then I changed gearing and tires and ended up swapping out so it was worth it.
KansasIDI
Wilsey, KS
I have this, it works fine.
KansasIDI
Wilsey, KS
I need this, it is screwed up.
BlindAmbition
SoCal
Green seems to be a 6 tooth
Yellow is 7 tooth from the looks of it
Try this link - might be a from a BW 1356 though, seems the 1345 is a rarer beast.
This one is for a 1345 but they are pretty proud of their gears to be charging that much
KansasIDI
Wilsey, KS
$62 dollars beats unobtainable IMO. Thank you!
KansasIDI
Wilsey, KS
Oh much better price. Is that a reputable company?
Black dawg
sw mt
Should add to, check the OD of both gears, have seen some undersized lately.
MadScientist
