sasquatch81
Hello Everyone, Ive been learning a lot from this forum and finally decided to join up. I purchased my first diesel 9 months ago and want to get some opinions on condition from the few tests I have done.
Future plans for the truck are as follows:
Moose IP " I believe the existing Pump is original and the truck is at 216,000 miles"
new injectors
new banks downpipe and 3" exhaust
coolant filter "would like to know thoughts on if these are worth installing"
Possibly more if my wife and wallet permits
I am interested in finding out if this engine is worth putting the above upgrades on due to the following conditions.
Truck starts great even in cold weather, It seems to smoke more when oil is topped off all the way? No smoke typically when truck is at high idle but then sputters smoke when it kicks down. It produces a slight haze of smoke when accelerating but clears up when maintaining speed. I have found oil in the intake coming from the CDR valve. I cleaned the cdr and it seems to seal when i plug the outlet and suck on the inlet "valve cover side" would like to know if there are other ways to stop oil from getting over too intake.
Compression # are as follows "cold engine"
#7 355psi #8 310psi
#5 370psi #6 405psi
#3 365psi #4 410psi
#1 410psi #2 390psi
I performed a leakdown test not going to guarantee accuracy because I used a homemade setup. supply pressure was set to 100psi and upon opening air to cylinder pressures dropped too between 70psi and 80psi. I heard good air movement into crankcase but did not hear air anywhere else, or see any bubbles coming from radiator. this test was also done while the engine was cold.
I guess my main question is what should be my next steps. I would be willing to make upgrades to the truck if it will last me another 100,000 miles but would like to know from what little info i have given if it is worth it or not. I know there may be mixed opinions but just would like to hear them.
I am concerned with Cylinder 8 especially and worry it is rings.
Any thoughts would be greatly appreciated and I hope I am posting correctly, I have never used a forum before so let me know if I am doing something wrong.
new injectors
#7 355psi #8 310psi
#5 370psi #6 405psi
#3 365psi #4 410psi
#1 410psi #2 390psi
