hey guys im new to the forum, and new to diesles. I have a 1994 f-250 7.3 idi. i got the truck as a gift from my step father. it has been stuck in his drive way for 3 years. before then it has had a very precise and meticulous service record. i changed the glow plugs and relay. i got a new alternator and i replaced the water pump. i put on some new batteries and the truck started right up. it runs and drives pretty good. it takes a little while to start up though, and when it does theres a lot of smoke coming out of the exhaust. it smokes kinda heavy when it starts up but starts to clear up after driving it around for a bit. on a hot day, or if it runs for a couple hours itll run warm. it wont overheat, but the temp gauge will show between the "A" and the "L" on NORMAL.
I work for a tile company, and my boss wants to buy my truck for work purposes. He needs it to haul large loads of tile and and materials. i wanna make sure this truck will be in top condition and reliable. what do i need to do to make sure my boss will be able to use this truck for years to come with just minor maintenance? im already thinking to replace the radiator, and the injectors. what else should i do to make to help fuel efficiency and reliability?
